3.0 engine project
This is a must see! I've been following this guy now for a few weeks and i was surprised to see the engine so small! Lots of info and the possibility of the outcome is huge!
check it out 4 yer self!
http://3litermotorproject.blogspot.com/
________
OLD MAN XXX
________
OLD MAN XXX
Well he's taking the engine apart, piece by piece and soliciting information on how to make/tweak up the existing parts for some performance gains.
As you can see the exhaust is in need to serious tweaking. The way the cats are positioned and the pluming of it looks like a nightmare let alone the heat they produce right there by the side of the engine block. We discussed a performance gain of at least 40 hp if the cats and mufflers were redone with aftermarket stuff....headers and maybe a 3 inch pipe..... (he is in the process of developing the headers) Which will one of the first.....
Once he has it all apart, notes will be taken, parts will be developed and bench tested.....etc...etc...Then he will install it in his 2.5 l jag and see what it can do....
It's kinda like a test engine type thing.....
If you have any inputs, I???m sure he'll appreciate it....
________
250 Gas Gift Cards
________
250 Gas Gift Cards
