3 Issues - Hopefully 3 Answers from you guys!
Again, I'm new to the X-Type and I have a few issues since I bought the car, but here's a little background...
2002 X-Type 2.5 Manual Sport with 75k miles for 12k
but with a few annoying issues:
Earlier this week, I noticed a styrofoam flap on the passenger side that was down. Since the tab didn't go back on, I just glued it back. Today when washing the car, I find a puddle in the floor. Looks as if it were coming from the blower? I was wondering whether this was linked to my A/C issue I have.
I had a problem with my power wash, well today after tinkering with some relays, I got it to work, however it doesn't spray with any pressure and the left squirter isn't working.
I have a small coolant leak somewhere that isn't the water pump or a head gasket, thank god. But I think it's coming from a hose. I'm not sure how much help you all can be from this tidbit of info, but worth a try.
So...a little help here!
SpartanX
SpartanX
Hi! congrats and welcome....glad to have ya
Just 3? I think you'll get a lot more...oh and dam You sure do ask alot of questions...
1st answer, your pollen filter is not installed or loose or crack. That's where the water is coming from.
2nd - bad washer pump or clogged (I'll go and say it's bad)
and finally......the last answer....can't help ya there buddy..you gonna havt'a crawl under the car and look yer-self....we is good, but we no do magic tricks....AND we don't have the all answering magic ball...
1. Racer is close. Water is coming thru the pollen filter case. You need to put silicone on the pollen filter assembly to seal. If you plan on doing this, i can give more in depth instructions.
3. Check the thermostat housing (near the front catalyst). The seal or hose are common leaks.
Received 9,007 Likes
![Name: T15ESSJAG5.jpg
Size: 6.3 KB](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/198274d1501344429-3-issues-hopefully-3-answers-you-guys-t15essjag5.jpg)
Try in the link below Spartan.............there are some really useful electrical wirng diagrams, hints n tips.
Check them out, they may prove useful
JC
http://jaguar.bttlxe.com/xtype
Remove the wiper arms, 13mm nut. Remove the cowl, pop the clips out.
Take out the cabin filter. Clean the cabin filter assembly. You'll need a good amount of RTV silicone, aply it to the back of the cabin filter assembly through out the entire length. This will keep the water from seeping into the cabin. If you have any questions just ask.
Your sunroof problem is the motor. You might be able to program it but it will probably loose memory after a while. Buy one. It's easy to replace.
-SpartanX:
-Again, I'm new to the X-Type and I have a few issues since I bought the car..
get ready for more.
-Today when washing the car, I find a puddle in the floor.
look under the hood,under the wiper cowl cover, see if you even have a cabin air filter installed.
-it doesn't spray with any pressure and the left squirter isn't working.
look under the hood, under the left squirter, pull on the hose and you will probably see the finely made plastic elbow has broken off. you will need to buy the entire washer hose to both squirters, pull the hose out of the fender and you will havea hose connection in there.
-(coolant) I think it's coming from a hose.
highly possible. there are brittle plastic hoses allunder the hood of this car that will break if you sneeze hard enough. the coolant reservoir is highly likely to have cracked andcould beleaking coolant from it too.
other items of interest, has your fuel filter and water pump belt been replaced at 70,000mi
get ready for more.
ORIGINAL: Envy337
Hey spartan have you recently jump started the car or disconnected the battery? Does your antifreeze leak when the car is just sitting or only while driving? I'd get under the car and look for leaks and spots where the antifreeze may have dried and left stains on the hoses...
ORIGINAL: aquill1
The antifreeze leak is when i'm sitting, I think. That's when I see it in very small amounts on the ground.
I'd try tracing it back when its a hot day and if its coming from hoses you can tell by the trail that dried on the hose...sorry I'm not much help...so many things it could come from! Your moonroof worked fine before that right??? Every time I've ever disconnected the battery and what not and all of the creature comforts that you grow accustomed to stop working intermittently! My windows stopped rolling up on there own when I disconnected the battery 2 weeks ago to try fix the a/c problem and my driver's window just started being able to use the one touch button for the window to shut by itself and all of my other windows almost worked instantly...or worked as far as the one touch feature...hopefully this helps...my guess is jumping the car sent a surge and the car will adjust soon enough! I'll hope for the best for ya just hang in there good buddy![sm=icon_cheers.gif]
When you disconnect the battery, you need to reset all the one touch features.
The way to do this is simple, basically roll the window down and keep the switch pressed after the window is all the way down for a couple seconds. Repeat when you roll the window back up, and voila the one touch works again =) You need to do this for all the windows, and it only works from the drivers door switch.
Same applies for the sunroof.
Basically it lets you choose which windows you want to have one touch...
Hope this clears things up,
George
George
Size: 6.3 KB](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/198137d1501344098-3-issues-hopefully-3-answers-you-guys-t15essjag5.jpg)
ORIGINAL: 04XTYPE
Nice info George, one of the mods mite want to add the post to the faqs section, im sure a lot of poeple will find this helpful
Only thing I've done is opened a new topic for it and named it, then cut George's comments and pasted into the new post, so that he gets credit for it.
I've done it this way because looking at the threads in the FAQ section, it can sometimes be hard to know whats what, which defeats the purpose.
This way the post is named for what it is and there should only be one post, so you don't have to wade thru page after page to find what you're looking for.
DONE!
JC
Spartan X the sunroof has a smart motor which can be re calibrated your self... just hold the close button.. until it closes but don't let go then the sunroof will open .. with your still holding the close button let it open all the waythen it'll be calibrated... and one touch will work again.
I've never reset my one touch features on any buttons and in less than a week or 2 they start working! Guess its kind of like my horn and door problems...the cars such a smart a$$ it decides when it wants to tick me off! Man I love my Jag! No lie either!
![Big Grin](https://www.jaguarforums.com/forum/images/smilies/biggrin.gif)
