ABS and brake warning lights on
Received 3,909 Likes
[QUOTE=Dell Gailey;2123309]Btw, you'll need a unit that reads "c" codes for a Jag. A less expensive "elm" type will not do it.[/QUOT
Look for an OBDII scanner that has the 1.5 version and PIC18F25K80
Viecar Bluetooth is fairly cheap, like $19 on amazon. It will read C codes. I originally got the Bluetooth because i was using my mobile to run Torque, and when i connect to the OBDII using wifi then i would loose connectivity to internet , With Bluetooth, i was connected to internet via mobile data and to OBDII via bluetooth,
Later on i got the Android 10" Mirror for my x type and now i can use either one, but bluetooth tested faster for me, i can see my information in (almost) real time,
I tested the symptoms yesterday,
Start the car, drive under 40 MPH, the light did not come on.
Once you go over 40 MPH, the light triggers.
I have error codes on my OBDII for all 4 sensors, although only one is bad, i know for a fact, the front left.
This is the OBDII scanner i am using
showing @ work
Reading C codes
showing @ work
Reading C codes
