ABS and Brake Warning Lights!!!
I have a '04 X-type 2.5L Manual and just had coolant system flush and wheel alignment done. After the coolant flush, they also soap downed the engine to clean up spilled coolant.
Once I started the car, I noticed both ABS and Brake lights are on that I've never had before.
The brake light sometimes turns off when I restart the engine but the ABS light is always on no matter what I do.
I'm not sure how the coolant flush and wheel alignment could have caused this problem and how to get this reset if I should.
Any information would be much appreciated.
