ABS and Ck eng light problem
I have a 2003 x type that illuminated the ABS and Ck Eng light after a front left side wheel bearing replacement. There is also a slight rubbing sound (regular and intermittent) from the front left side. Codes c1165 and c1000. I have replaced the speed sensor- no change. I think it may be the speed sensor ring- if it is, how do I get to it (is it easy to replace?) and where might I find one?
Much thanks to any help!
innzane
09-02-2015 10:08 AM
