ABS/DSC question (Bad ABS module) DSC fault
![Lightbulb](https://www.jaguarforums.com/forum/images/icons/icon3.gif)
Dear Jaguar enthusiasts,
This may be off the wall and forgive my ignorance; Just trying to think outside of the box regarding a 2005 X-Type with a bad ABS module, per my mechanic(it is a refurbished module).
My thoughts:
ABS/DSC(from my knowledge)assists the car in unstable conditions such as snow/rain, right? I live in Florida and do not do a lot of driving with this car. My Question is, is it possible to get rid of the ABS module(or disable it)and hack the computer to bypass(somehow)the system in order to get rid of all the lights??? ABS light, check engine light, and DSC fault showing and cruise control not engaging. - I am more mad that cruise control is unable to engage.
If possible, what are the consequences? What kind of impact may it have on the AWD system(just thought about this)?
Interested to see responses,
My thoughts:
blackonblackXtype05 (01-03-2017)
Thanks, JagV8 for the response.
So what you're saying is, I cannot hack the system and bypass ABS in someway, right? In order to get rid of the warning lights. Or eliminate ABS from the system in order to eliminate the warning lights. I ask that because my ABS module is deffective and my car is still driving without issue(besides cruise not being available). So it makes me assume I really don't need ABS/especially DSC....
blackonblackXtype05 (01-07-2017)
Thanks, Dennis, alfa dude, & JagV8
He didn't show me the codes or tell me. And I also didn't ask because he mentioned the ABS module is not communicating with his system. I have an Autolink AL319 code reader and the codes I get is P1646 and P1000
I have the check engine light on, ABS light, DSC fault on screen and light on, cruise not working. And before I turned sport mode off the vehicle stuttered a couple of times with a transmission fault coming on and a red exclamation mark light came on (!) and a (P) light(same light for parking break). Both lights in circles. - As I said these lights and stutter have not returned since turning sport mode off. When the ABS was bad per the mechanic the first time(original one that sold the car)the vehicle would barely move and DSC light was on. It would stutter but somewhat worse.
Jag V8,
Again, thank you so much for your replies!
Brand new battery installed a few months ago...
I'm obviously not as knowledgable as you guys but the lights and faults seem to tell me that it is not just an o2 sensor? DSC fault/ABS light? Unless I have a bad o2 sensor on top of a faulty ABS module? I AM LOST!!
First time mechanic ran the codes they came back as intake sensor. I told him that my code reader read o2 sensor. But he said his code reader is not showing intake sensor anymore or o2 sensor and that the ABS module simply is "unable to communicate with his system."
LOST, I AM
Again, when I first took the car for a test drive a year ago before i bought it, the car stuttered along when pressing the gas and DSC fault was on(can't remember if ABS was on). Mechanic said it is the ABS module and will replace it with a refurbished one. Once he did that, the problem was fixed.
fast forward, the DSC light and fault would flicker on and off at times while accelerating. Other times it would stay on until the car was turned off and then back on again during normal use. Now my dash is lit up like a christmas tree with the ABS/DSC light and fault/check engine.
So.....that is what brings me to conclude that just maybe this refurbished ABS module took a dump again...although it doesn't stutter along....??
LOST, I AM
blackonblackXtype05 (01-09-2017)
