Abs engages when making right turns
About 1 month after I changed my brake pads and rotors my abs started engaging with light braking, after s bit the abs light would come on. I had it scanned and came up with the right from abs sensor, swapped it with a new one and no change at all. It now seems that it won't do it unless I am making a right turn and then it engages.
I am thinking a bad reluctor ring but don't wanna tear it apart if somebody thinks it might be something else.
Received 10,916 Likes
My X-type experience and knowledge is nil, but, just to throw something out.....
I had a problem with my XJR where the ABS light came on only around corners. Long story short....
The reluctor wheels is pressed onto the hub. A worn rear wheel bearing caused excessive movement of the hub...particularly when cornering... allowing the reulctor to move away from the sensor, disrupting the reading. On disassembly for wheel bearing replacement I also discovered the reluctor wheel was loose on the hub. On reassembly I used Loctite to ensure it didn't wobble.
In doing a little more research, it looks like the wheel bearing is tied to the abs system, is it possible that the uneven wear, pulling and abs issue is related to a bad bearing in the front right? I have been getting a weird high pitched noise but I thought it was my carrier bearing.
jagnation89
10-17-2015 01:48 PM
