ABS FAULT PLEASE HELP ME OUT WHAT DOES THIS MEAN HELP !!!
Guest
Posts: n/a
Good thing I have Select Edition for backup. Anyways I was driving my car thru snow and ice, and the ABS light came on it said ABS Fault. What does this mean ? Is ABS simialar to the Electronic Stability Control ? I had ESP in the Benz, is this whats it like for the Jag ABS ?
Guest
Posts: n/a
anti-lock braking system, been around since the 80's..... I would try to google, or wikipedia "ABS" and you will find a ton of info on what it is and how it works.
It means that there has been a fault detected in the system. you need to get the code read before you can diagnose the problem. I tried the local car parts place that will read the codes for free, and it was able to pull an abs code for my car.
what car do you have? if it is an S type, then nobody here will know typical problems.
by the way....... There is no "s" at the end of the word "anyway" -- sheesh a benz driver gone to Jag should have a little more language skill.. lol.
Received 9,010 Likes
goges
10-05-2015 04:53 PM
FS[NorthWest]: 2004 X-type 3.0 24,500miles! $8500
millertic
09-30-2015 08:11 PM
