ABS light on
Received 3,915 Likes
Have you done any brake work lately? What about new bearings in the wheels? Each wheel has a speed sensor in our cars and they use a magnetic pickup that is run close to a toothed gear in each wheel. If this gear gets off center from the sensor or if it gets rusty, it can cause the sensor not to output a good enough signal, leading to the confusion of the computer.
If I remember right, with our cars, we normally have issues with the rear speed sensors for the most part. But, if your front wheel bearings start to go, that can cause enough play to move the ring away from the sensor, leading to the same indications.
rsa760041
23
09-25-2015 01:33 PM
innzane
09-02-2015 10:08 AM
