ABS Light On
"P1267 Cylinder #7 High To Low Side Short."
I have no idea what that means.
Here's a List of Diagnostic Codes elsewhere on this forum. and look in the sticky threads, lots of good info there.
I think you are supposed to clear all the codes since you don't know how old they are and then see which ones come back.
The reason for a P1267 OBD-II Engine Trouble Code is Ambient Air Temperature Sensor Circuit Low.
https://www.sngbarratt.com/us/#!/Eng...d8c?gt=Ambient Air Temperature Sensor for Jaguar X-Type
Your ABS light on makes very little sense.
motorcarman (05-12-2019)
ABS Light On
Thank you very much for your input! I am so Sorry for sending you an incorrect fault code. The actual fault code is C1267 not P1267. This code coma up if an internal failure has been Detected inside the module. The ABS light comes on immediately after turning the key on, and stays on even when the engine is running.
Few days ago I replaced the both the ABS module and pump with matching numbers. The problem was solved for few minutes but came back again.
The forum is my last hope.
https://www.google.com/amp/s/www.aut...des/c1267.html
You can also download the workshop manual under "stickies". It has a diagnostic flow chart to run down this fault code.
ericjansen
12-19-2021 12:20 AM
bullittandy
03-03-2017 04:44 PM
innzane
04-03-2016 08:43 PM
prince_kuja
XJ XJ12 ( X305 )
02-18-2015 12:32 AM
babbah
XJ40 ( XJ81 )
09-14-2010 04:58 PM
