ABS Light Codes C1155 and C1145
After replacing both front wheel speed sensors due to a lingering ABS light, intermittent brake light, and check engine light for codes C 1145 and C 1155 (left and right front wheel speed sensor faults) I discovered that the sensors were actually ok and it's a wiring problem.
Going to pull the wheel ABS wiring harnesses apart tomorrow and try to find the bad section of wiring and hopefully patch them up if at all possible as they are $80 each new.
Wish me luck and I'll post some pictures when finished if successful.
Wheel bearings are in correctly, made sure of that when I put them in last month, magnetic side facing in towards the engine.
Pulled the wiring harnesses apart from the inner fender to the wheels, both of them are ok, so looks like it's either between the main wiring harness to the ABS computer or it might be the ABS computer itself.
Guess it's one more project for another weekend.
jimborino (05-20-2014)
OkieTim
09-08-2015 04:48 PM
innzane
09-02-2015 10:08 AM
