abtt light
I have problems with the battery light coming on some times .came on this morning again, got meter out across battery charging at 14.47 volts ,engine off 12.30 volts , some time it flashes ,some stop on for a few minutes ,then it stop off for a couple of weeks any ideas
thanks
stu
thanks
stu
Clean and polish the battery cable connections. Also check the cable connectors for corrosion and fraying. You are getting high resistance under a load. To be sure next time the light is on put your hand near the cable/battery posts. You will probably find they are to hot to touch.
If it continues after cleaning then you are faced with a failing cable.
caldercay
01-14-2016 06:26 PM
