ac clutch bypass
ac clutch bypass
2002 xtype 3.0l
Changed dryer, o tube, compressor, and flushed.
Held a vacuum ok, so i started to charge.
Can't find the pressure switch to bypass so the clutch with engage.
There is a switch on the high side, to turn the fans on high.
The switch may be on top of the compressor but I can't find anything else.
Thanks Andy
aandy767@yahoo.com
Thanks Andy
aandy767@yahoo.com
Received 3,887 Likes
RE: ac clutch bypass
no joy,
jumped 3 to 5. that's what is printed on the side of the relay also. 3 and 5 are the long ones right?
poked a volt meter into the red wire to clutch and grounded black to the case and no volts.
The rebuild shop put the plug forward on the compressor not on the top. the only thing I can think is to pull it and see if the wires to the plug are in good shape.
they were working fine when I puled the compressor the first time.
Any more thoughts?
Andy
Any more thoughts?
Andy
