Aftermarket Nav for X
Looking to replace factory CD/radio (not premium) with aftermarket unit with navigation, I really like Garmin so would prefer nav unit to be based on that, looking for nice sound but anything as good or better than factory is fine, what fits and does anybody have any recommendations based on experience, as i say I particularly like Garmin.
I would prefer the non-popup style (double din?) and am looking for something mid range, not cheapy but not most spendy either.
Thanks for feedback...
Based on what I have seen so far, unless you install a jag navi system. Apparently dealer won't do it and it seems to be pretty complicated to do on your own, all the after market solutions are trade-offs in terms of look and feel. Here is what I found:
1. The head unit is placed too low in the console so you're looking down at the navi.
2. You need a console adapter and the end result in my opinion does not look well integrated.
3. But, you have no exposed wires, a one stop fully integrated system.
Options:
1. Get the jag ACM. You get multi AUX/USB interface to play/charge almost any mp3/phone system. Plus it is neatly hidden in the center arm rest. This addresses the no AUX problem of the factory unit. Plus in my opinion is a great solution if you use iPod/iPhone since you control everything from your stock controls.
2. Get a portable GPS unit. I use my iPhone. If you want a permanent install use a solution like Pro-clip. You can place the navi unit at eye level. The installation looks well integrated and in the case of an iPhone they even have a permanent powered dock.
3. In my case I use the Navigon iPhone dock which has the same finish as the x type center and has excellent build quality. It comes with a USB charging cable that you can use as needed. I think the look is pretty clean and the navigation features beats anything I have seen in an in car system it portable navi. It's also very fast.
4. The only problem with the ACM + external GPS is that the GPS audio isn't connected to the car. You can of course connect it to the ACM. However, even if it isn't connected to the ACM, if you're using a smartphone like the iPhone for GPS, when a call comes in or if you dial out the Bluetooth in the car will halt the music and route the call to handsfree mode.
My current x type is the first car I've had since 2003 without inbuilt GPS, but it had the most effective GPS system from a usability perspective. Doesn't look bad either!
Options:
From what I gather swapping in a double din unit isn't too much of a chore, Metra makes the piece to adapt the dash / console, you need a certain depth unit because the AC unit is right behind it so you're constrained. Dennis Blach has a whole write up if you search. He lists every piece needed and dimensions. I think if you put in the fascia piece you can get an installer to do the rest.
Swapping in the Jag NAV unit is more of a chore and super expensive. The information runs off a DVD in the trunk, not the stacker a separate DVD player just for the map disk.
jagkid (04-12-2011)
Not sure what you mean, the HVAC controls are separate from the radio controls, regardless if you have a nav system or not. Wen you replace the radio with a double din unit the heater controls above the radio stay there. Although they come out together you can separate them and reinstall the heater controls.
I think the hardest part is making the electrical harness. As far as I know you can't buy it anywhere.
Not all of the hvac controls are under the screen only auto, speed, defroster and temp. The control for the vents are done through the screen. I guess I could leave it auto, that's not such a bad trade off I guess.... And I don't like how slow it is and how they left mid eq level control on a premium stereo is beyond me. Plus it could use a better range eq altogether. And routing is never smart it gets you there yes, but when I use Tom Tom or navigon on my phone they always set much better routes and more optional routes Also it gets stumped on highway Like us1 if it's actually called rt1 it won't give options to pick the right name it just gets stumped and gives you nothing
Compared to factory head unit you got the following extra:
Nav, iPod integration ( you'd need o add ACM on the factory unit), DVD,
reversing camera ready, sat radio ready
What you would lose
The Steering wheel control ( although it had it's own remote that you could use), not sure of others....
My impressions and feedback:
1. If navigation is your main priority then you should consider retrofitting a Jag OEM system. My dealer wants $1500 to install it ( amazing but they agreed to do it) and I've seen the system available on eBay for around $600. Plus the dealer said they had all the cables etc. So the cost was very comparable - $1850 v. Appox $2100.
2. The thing I did not like about the after market is that the screen sits much too low so using the screen can be a little distracting. The jag screen sits higher. Plus, with the jag system you get the super cool lleaper logo v. pioneer.
3. I thought there was too much empty space around the unit, although these guys did a really nice carbon fiber finish so it match the dash which was also carbon fiber. Did I say this was a sweet looking STR! Black with red/green accents.
4. The after market unit of course has way more features. But in my opinion does not look as well integrated as the OEM unit.
So it can be done, and apparently there are shops that even do it without too much trouble.
I just happened to ask and they said...yup.
Aluni said: What you would lose
THATS NOT TRUE
I have a Pioneer Avec 750 and my steering wheel controls work with this:
http://www.dynamicsounds.co.uk/product_info.php?products_id=9075{4}14
THATS NOT TRUE
THATS NOT TRUE
THATS NOT TRUE
