AGM battery
Old 06-30-2024, 01:28 AM
Playerpetegunn's Avatar
Default AGM battery
Can I use an AGM battery for my car 2008 xtype 3.0? The battery is from a 2024 Explorer
Old 06-30-2024, 09:40 AM
dh53's Avatar
I would be concerned that the unusual charging system in the X-type that goes to 15 Volts might not play well with the AGM battery. If you charge an AGM battery too fast the battery won't last long. If you charge it the way it likes it will last longer than a lead acid battery. I would try the battery manufacturer for info, specifically what the "fast charge rate" is. If you exceed that you will damage the AGM battery.
Red (07-09-2024)
Old 06-30-2024, 09:47 AM
Thermo's Avatar
Received 3,928 Likes on 3,224 Posts
AGM batteries are used in the XJ's. So, I would say you should be good to go.
ahrbruz
02-20-2019 04:50 AM
TheTerrible Keleb
01-06-2019 10:04 PM
Jagstefano
12-26-2018 04:25 AM
mojorising
10-26-2010 09:52 AM
rjs852
10-05-2010 12:34 PM
Quick Reply: AGM battery
