Air bag light
When you first start the engine observe the air bag light it will give a series of flashes. The first flashing is one number , it will hesitate and then flash another time. That is the second number. It will repeat the sequence 3 times and then stay lit. You may have to turn the car off and restart to catch the sequence. An example would be the light flashes 2 times and then flashes 4 times that would be trouble code 24.
Count the flashes and post the number and we can help resolve the problem.
One of the most common problems and the easiest to check is the wiring connector under the seat. Moving the seat back and forth will sometimes cause the wire running from the seat belt buckle to the connection under the seat to come loose.
In case anyone ever needs them, here are the codes. The most common are 13 & 33.
13 - Crash data memory full
16 - Pass seat weight sensor CAN fault
17 - Pass spatial sensor CAN fault
18 - Pass airbag deactivate lamp circuit fault
19 - Airbag circuit status fault – driver
21 - Airbag circuit status fault – pass
22 - Side Airbag circuit fault – driver
23 - Side Airbag circuit fault – pass
33 - Seat Belt Pretension fault – driver
34 - Seat Belt Pretension fault – pass
42 - Impact sensor circuit fault – front
43 - Impact sensor circuit fault – driver side
44 - Impact sensor circuit fault – pass side
51 - Seat belt switch circuit fault – driver
52 - Seat belt switch circuit fault – pass
53 - Airbag audible warning circuit fault
54 - RCM configuration failure
dh53 (06-26-2021)
I know several members have the icarsoft diagnostic tool, but if you buy the slightly higher priced one you get module reset features, airbag, cycling of abs, open & close brake pads, etc.
• LR II can do it all-reads and clears trouble codes on all the systems such as engine, transmission,
ABS and airbag etc.
• Read Data Stream
• Full ECU Diagnosis
• Applies to the entire models of LR equipped with OBDII-16 DLC
• Easy To Use With Metal Dome Keys
• Oil Light/Service Reset:Support service lamp reset, Brake pad reset function, Steering angle sensor calibration etc.
EPB:Opens and closes the brake pads,Reads and clears EPB/SBC trouble codes,
• Turns off the ECU and brake warning light,Diagnoses EPB/SBC caliper functionality,
Resets the brake pad thickness service etc.
• ABS/AIRBAGiagnoses ABS/ SRS system codes,
Reads/clears codes of ABS/SRS system and turns off ABS/SRS warning light,
Performs bi-directional tests such as cycling the ABS solenoids, Retrieves ABS/SRS ECU information etc
iCarsoft LR II for LandRover / Jaguar_Landrover Scan Tools
ABS and airbag etc.
• Read Data Stream
