Air bag light
When it flashes note the sequence (code). Then look up in SEARCH the reason for said code.
13 - Crash data memory full
16 - Pass seat weight sensor CAN fault
17 - Pass spatial sensor CAN fault
18 - Pass airbag deactivate lamp circuit fault
19 - Airbag circuit status fault – driver
21 - Airbag circuit status fault – pass
22 - Side Airbag circuit fault – driver
23 - Side Airbag circuit fault – pass
33 - Seat Belt Pretension fault – driver
34 - Seat Belt Pretension fault – pass
42 - Impact sensor circuit fault – front
43 - Impact sensor circuit fault – driver side
44 - Impact sensor circuit fault – pass side
51 - Seat belt switch circuit fault – driver
52 - Seat belt switch circuit fault – pass
53 - Airbag audible warning circuit fault
54 - RCM configuration failure
