Air bag removal steering wheel 2004
Guest
Posts: n/a
Hi to remove the airbag from later than 2003 models its a simple task. Remove the cowling around the ignition then with the aid of a small morror and a stumpy flat screwdriver look at the rear of the wheel u will se 3 square holes one each side and one at the bottom( you will need to turn the wheel to access each one in turn) simply put the screwdriver in the hole and unclip the retaining wire when you release the last clip the bag will simply fall out. unclip the connectors on the back of the airbag by pushing the tab forward and pull DONOT try to unclip fron the internal part of the wheel where the audio connector is you will need a torks bit 45 to undo the whhel its self if you need any help doing this PM me i will gladly assist
Doberman_Fan
22
12-24-2019 06:21 AM
