Air conditioner dead.
Guest
Posts: n/a
It is getting a little warm around here so I tried the A/C and got nothing but hot air. I can see that the compressor clutch is not energized (yes the rotor is there). The compressor pulley is spinning. I checked the fuse which was good. I swapped the A/C relay with the horn relay (Same size unit). Still nothing. I don't hear the relay click. The light in the AC button turns on and off as it normally does. I can push the compressor around using a long wooden stick and it feels OK. What can cause the clutch to be not energized?
It is a 2003 X-type with 126K miles. The car runs fine otherwise.
Thanks.
Thanks.
RE: Air conditioner dead.
Are you sure the clutch end plate is still attached? The most common failure is the clutch falling off.
Failing that, you need to make sure voltage is getting to the clutch to energize it. Failing that, check there is actually refrigerant in the system. If there is 800grams in there, then you need to check that the ECM is commanding the compressor to turn on.
Guest
Posts: n/a
I believe that the clutch is OK in the mechanical part. I can push the plate around while the engine is running. The pulley is spinning but the clutch is not.
If I pull the relay out while the engine is running and plug it back in I don't hear a click. I am not sure if it would be loud enough to hear anyway.
How can I tell is the ECM (Engine Control Module??) is commanding the compressor to turn on? The AC button seems to be working normally. I set the temp setting low.
I have an AC guage set but they are the old type. I understand that the threads are different on the new systems. So I don't have a good way to check the pressure. Is the car's computer able to detect low pressure? My (limited) understanding of car AC systems is that there is an over-pressure switch that causes the fuse to blow thereby forcing you to service the AC when there is a problem. Is that the way that this system works?
Thanks.
Thanks.
Guest
Posts: n/a
I did some further experiments. By carefully slipping two small screw drivers under the cover of the relay I could pop the cover off without breaking anything. Then I could press the relay flapper to energize the compressor clutch. This worked and the compressor ran. So now the fuse and circuitry are definately good. The clutch is good.
However the condensing coil in front of the radiator did not get hot and cold ait did not come out of the vents. It seems that I have lost my freon charge. I can't think of any other reason why I would get no cooling with the compressor running.
Thanks,
Thanks,
You need to get the system evac and recharge. It could be that the compressor has started to fail internally. You need to evac out the system and pop off the line on the passenger side and remove the fixed orifice tube. See if it is blocked with metal filings. If you evac out only a little refrigerant, then you have a leak. 90% of the time on x-type is the compressor leaking or the evaporator. If evaporator, you have to remove dash. Did you inspect for damage at the condensor? A little pin hole....would have green around it.
Anyway, get it evac'd and see how much comes out. Should be about 800grams or a little less. If it is way low....look for a leak. But to do this you will also have to fully charge it.
I have an a/c problem too and I'm hoping you guys don't mind me asking for a little help? My a/c is not blowing cold either. I notice there's a constant squeak when the a/c is on. Is the clutch not engaging or maybe a loose/worn belt? Any help would be great.. thank you
bubbawing...is the compressor locked up. In other words, can you visibly see the pulley race of the clutch and pulley assembly rotating? If the compressor is locked up but the clutch engages, it will not let the pulley spin and the belt will burn and squel on the pulley. With the engine off, key out of the ignition,try to turn the front of the clutch by hand. If it doesnt budge your compressor has failed.
Guest
Posts: n/a
Here is the resolutionto my air conditioner problem.
After doing all the tests that I could myself, I made an appointment with
the dealer. They checked it out and said that I needed a new A/C
hose assembly, somethingthat needed to be ordered.
Whenit came in and they installed it everything worked fine.
I asked to have a look at the bad hose. They showed me
the place where it had leaked. It seems that a bolt had been
rubbing against the aluminum tubing portion of the hose assembly.
Eventually the bolt wore a hole right through. The rubber portion
was OK.
A couple of years ago the car was in a serious front end accident.
The A/C core and the radiator were smashed. I suspect that the
aluminum tube was bent at the same time.
Now the summer will not be so hot!
Thanks for everyones help.
was OK.
ORIGINAL: FactoryJaguarTech
... I don't think it was your accident that caused it. I have done alot of Xs with the same problem.
You remove the front lower splash shield and you will see the line on the right side where the metal radiator support goes. If it is touching the support just bend it away a little bit. When I say I have done a bunch, remember that is relative to how many X-Types are on the road.
scooternva
20
09-27-2023 11:25 AM
mel
09-20-2015 04:56 PM
Guy-Pierre Boucher
09-16-2015 05:55 PM
2003, ac, air, compressor, conditioner, core, jag, jaguar, leaking, location, orifice, refrigerant, tube, type, xtype
