air conditioning
Old 08-08-2007, 05:36 PM
billinohio's Avatar
Default air conditioning
granted it's been over 100 degrees here in ohio, my 02 x-type sport isn't really keeping me that cool. any advice? not sure, completely new to jag and looked for previous posts
Old 08-08-2007, 06:01 PM
Envy337's Avatar
Default RE: air conditioning
Does your recirc. work? Check for freon leaks.
Old 08-08-2007, 06:08 PM
SpartanX's Avatar
I'm having issues again with my Aircon also. It works, then shuts off. Works, then shuts off. It did that all the way home today in my 45 minute commute.
Recharge? Possibly? I can hear the compressor engaging on/off as it's doing this every 10 minutes or so.
Old 08-08-2007, 06:20 PM
billinohio's Avatar
yes recirc works. it gets kinda cool, then blows not so cool air. when i'm accelerating it stays cooler. it seems that when i'm idling it gets less than cool
Old 08-08-2007, 06:31 PM
coolings fans may not be working, does car overheat?
SpartanX, u maybe having same problem, when caris idling,
turn a/c on and check fans if working, they should come on with a/c
on, if fans come on and off, is going bad. well not really the fans
but cooling fan module.
billinohio's Avatar
hey spartan? that anthracite? i think mine's close to yours. 2002 sport anthracite, loaded, just no 6 cd changer. how many miles
Old 08-08-2007, 06:33 PM
billinohio's Avatar
nope runs well and i hear the a/c switching on and off. is it possble i have a loose belt? when i accel it gets and stays cold
Old 08-09-2007, 12:32 AM
SpartanX's Avatar
ORIGINAL: billinohio
Bought it with 70k on the ODO. I have 84k on it now, and I'm loving it. If I can get this aircon working all the time, I'll be fully satisfied. Well, can't really beat it for $12k and $50 a month for insurance.
Old 08-09-2007, 12:37 AM
SpartanX's Avatar
ORIGINAL: cap79
Even with the compressor switching on/off? I was thinking it was low because as soon as the compressor shuts off, the air just gets steamy hawwwt! But now that you say that, the fans shut off too, as if the A/C has been turned off manually from the climate control.
Old 08-09-2007, 03:51 PM
aquill1's Avatar
Not saying this is your problem but mine did this before I replaced the fuse/relay inside the engine bay...pop the hood find it and try replacing that...mine did everything you guys state until one day it was 96+degrees and humid here in michigan with my baby in the car!
Old 08-10-2007, 08:40 AM
billinohio's Avatar
not to sound completely ignorant. was it a fuse or a relay? and do you just pop the cap off the fuse box(under the hood) and replace? and which one? thanks, Bill
Old 08-10-2007, 02:00 PM
SpartanX's Avatar
Bad news if it's the cooling fan module...
You can't get the module by itself anyomre. You have to buy the entire fan assembly, which will set you back about $500. To top it off, it's on back order for at least 2 weeks. Not as if I'm going to buy it anyway, but whatever.
Meanwhile, my a/c still cuts in and out daily.
Old 08-10-2007, 02:20 PM
aquill1's Avatar
It was a black ford relay... can't remember the specifics on it I'll look soon as I get a chance!
Old 08-11-2007, 08:19 AM
billinohio's Avatar
thanks aquill. found what seems to be a temporary fix, start your temp at say 70 degrees then gradually make it cooler, this worked for me me just yesterday. Bill
Old 08-11-2007, 10:20 AM
billinohio's Avatar
please let us know what relay(ford) you used aquill, when you can. Thanks, Bill
Old 08-12-2007, 08:31 AM
aquill1's Avatar
On the side of it it has 61UHQ below that it has >PA66GF25<
On top below the big FORD symbol!!!
F578-14B192-AA
I'll get a picture of the fuse/relay box in the engine soon as I get a chance...
Old 08-12-2007, 11:02 AM
Cadillac's Avatar
I hope we don't see TATA logo in the future !
Old 08-12-2007, 11:17 AM
I know I'm a newbie here, but that sounds like it needs a recharge. My work van was doing the same thing (cool air at higher RPM's and warm air at idle). Recharged it and its good as new. I think there's a pressure switch in most A/C systems that will shut the system down if the pressure gets too low to keep from burning itself up. That may be why it shuts off and on all the time. Pressure buillds enough for the system to operate then falls tripping the switch shutting the system down. Just something else to think about.......
Old 08-12-2007, 12:39 PM
SpartanX's Avatar
I'm thinking i'm in need of a recharge also, but here's my dilemma:
Mine only does this in EXTREME HEAT. At night, if I turn on the A/C, it doesn't do it as much. However, it doesn't get ice cold as it once did when I first got the car.
I may just get it checked because I'm tired of playing the guessing game with this.
Old 08-12-2007, 10:06 PM
aquill1's Avatar
Honestly spartan mine did the same thing...I went and bought the recharge kit put the freaking can on the quick connect tool and put it on the low pressure port and it read FULL!!! WTF??? So needless to say i paid 30 bucks for the kit that I had no need to buy. My car would get freezing cold and than like only half work or get cooler than the regular vent being on but not cold...finally my relay blew one day and since than I haven't had the problem...??? Prolly just another jag thing!!!
Quick Reply: air conditioning
