airbag lights
Guest
Posts: n/a
airbag lights
Hi everyone im back! ok so my 04 x-type keeps popping the 10amp fuse insid the car. When the fuse blows both airbag lights(driver and passenger side)come on and dont go away until the fuse is replaced. The problem is when i replace the fuse it only lasts about 5 minutes before it blows again! Any ideas as to what might be going on? I dont especially care for driving around without my airbags! thanks, Val
Received 2,192 Likes
Guest
Posts: n/a
RE: airbag lights (brutal)
Ok went out and changed the fuse , then started thecar from outside . airbag lights came on and cancelled as they should so i shut the car off removed the keys then put them back in the ignition and started the car again. the airbag lights stayed on. any further advice and thanks for the previous answer!
Guest
Posts: n/a
EVERY JAG IVE HAD THAT KICKS THAT FUSE HAS ENDED UP BEING THE WIRING IN THE DRIVERS SEAT. MANY TIMES AT A CERTAIN POSTION, WEIGHT IN IT, OR IS A PERMANENT SHORTTO GROUND. UNBOLT THE DRIVERS SEAT, DISCONNECT THE ELECTRCAL CONNECTOR FROM THE SEAT AND SEE IF THE FUSE BLOWS AGAIN, THE LIGHT WILL STAY ON SINCE IT DOESANT SENSE THE SEAT POSITION OR AIR BAG AND PRETENSIONERS, SO DONT GO BY THE LIGHT STAYING ON
Guest
Posts: n/a
Thanks again Brutal my husband just went outside and noticed a ford part that says delphi on it hanging under passenger seat it looks like it was attached to the bottom of the seat bbut the tabs are broke off. could this be anything to do with it ? He will try unbolting the seat tomorow with better light, and must he undo all 4 bolts or just one inparticular? thanx again
FS[Western US]: XJS Lock Set with Keys- Doors, trunk, glove, gas, and ignition
XJsc-guy
11-23-2015 01:56 PM
rsa760041
23
09-25-2015 01:33 PM
34by151
09-06-2015 05:14 PM
