Alarm - No turn signal flashing
Received 3,887 Likes
While the Passive Security system has quite a few fault codes, there are very few for the Active system and none relating to your particular problem. You need a Jaguar enabled scanner to read such faults; a cheap generic one will not do.
Just because any system has a fault does not mean that system will necessarily fail completely, but one way you could check yours out would be to double lock the car which should set the active security system fully. Now jack the car up on one side . If the alarm is working the inclination sensor will set it off before you get it very far up.
Another check would be to double lock the car then use the key in the driver's door lock to unlock the car by turning the key forward. Open the door and there should be a warning series of pings. If you don't put the key in the ignition within about 10-15 seconds, that should also set the alarm off.
