Alternate Parts?
I heard jaguar parts are very similar and/or the same in certain areas as to the lincoln vehicles. My only question is what class/model?
Where I am going with this is, I was wondering if there were alternate parts for calipers and rear control arms for the jag. Reason being is there are not many parts in the auto catalog for jags at local stores. And last time I bought calipers online, the shipping costs gave me a heart attack due to its weight.
Adjustable rear control arms from an volvo s40 (made by ford at the time) fit our cars. The problem with the calipers is that the lincoln ls and the stype are essentially the same car. However, the xtype doesn't really have a sister vehicle. That means that things like the ac compressor will be the same on lincoln vehicles, but calipers will not due to them being manufactured specifically for the xtype body. When I had my calipers go out, I bought them used on ebay for $35 shipped to my door.
Fezz (01-31-2013)
The X type is a spin off of the Mk3 Ford Mondeo /Contour platform 2000--2005. The rear suspension is highly modified Mondeo station wagon . some rear brake & roadwheel components may be similar . Gas engines are again , modified Ford Duratec units 2.0 , 2.5 & 3.0 litre , I think mainly modified heads .
Apart from Jaguar modified platform , I think only about 12% of the X type has any link to Mondeo/Contour ...
Fezz (01-31-2013)
According to the write-up, apparently just the block of the engine is original Duratec. Jaguar invested quite a lot of effort into the kitten, far more than I initially realized. This ranking is a testament to the work they did to make this car handle well; 11th in quite a hard company!
I seem to recall several someones mentioning the idea of fitting Mondeo ST220 brakes to an X-Type as an upgrade, so perhaps there is some connection in the brakes too...?
EDIT: I so have to try this sometime in a controlled environment...
![Big Grin](https://www.jaguarforums.com/forum/images/smilies/biggrin.gif)
"This system enabled the X-Type to power down from 60mph to standstill in just 2.5 seconds."
Fezz (01-31-2013)
Received 3,894 Likes
Fezz, it sounds like you are kinda handy when it comes to the car. How does new calipers for free (or worst case $12) sound? Most of the time with the rear calipers, the problem lies with the e-brake lever freezing up. You can rebuild the calipers yourself. I have done 2 of mine. The first one I did, I had a rebuild kit (can be found on e-bay for fairly cheap). But, after doing the first one, I realized that I could rebuild the caliper re-using all the old software and just cleaning up the part that was freezing (due to rust forming between the body of the caliper and the shaft for the e-brake lever. But, with this being said, you also need to factor in buying a 14mm Pentasocket (yes, a 5 pointed socket). Again, it can be had on e-bay for around $20 delivered to your house.
As for other parts, it is really hit and miss. There is some stuff on the engine that will transfer over, but things like the water pump and whatnot will not transfer over (the water pump on the LS is on the front of the engine-near the passenger wheel but on your Jag, it is right next to the battery box on the driver's side/back of the motor). As for the suspension parts, if you can get Mondeo parts, you may save a little bit, but again, it is hit and miss.
Like was mentioned, I recently discovered that the rear upper control arm is very similar to the Volvo S40 arm. You may want to look at the Volvo line and see if anything is shared there (as they are both Ford products). But, what crosses and what doesn't, can not say.
If you have specific things that you are interested in, let me know and I will see what I can find for you.
Fezz (01-31-2013)
Appreciate information guys. And Thermo, I'll definitely look into rebuilding the calipers, would be another experience to try out if it saves money. In regards to the e-brake freezing up, I started to avoid using the e-brake and just park the car in gear (5-speed). But regardless of the fact, sometimes when I start my car next morning and begin to leave, I'll hear a "clunk" and all is fine after that. Is that noise e brake being stuck? I always thought it was. And, is there any way to modify/avoid this common jag problem?
Fezz, what you are probably hearing is the pads "rusting" to the rotor. This is a common problem with modern day brake systems. Some cars are more prone to this than others. The "clunk" you are hearing is the pad breaking the rust bond. IF you pay attention, the first few times you brake, you will also hear a thunking sound as you are wearing the high spots off of the rotor from where the rust formed on the rotor. NOthing to fear.
If you need to know more about this, let me know. I know I get this thunk if I have left my car sit for a few days.
Fezz (01-31-2013)
19%
See this article.
EDIT: I so have to try this sometime in a controlled environment...![Big Grin](https://www.jaguarforums.com/forum/images/smilies/biggrin.gif)
Here are the front caliper kits. Please note, 1 kit only does 1 caliper. So, you may need 2 of the kits depending on what all you are doing.
Centric Parts 143 20013 Front Caliper Kit | eBay
Here are the rears. Again, 1 kit does 1 caliper.
Centric Parts 143 20008 Rear Caliper Kit | eBay
But, from there, you have the Centric part number and you can possibly find the kit a little cheaper with some work. UP to you.
aholbro1
08-05-2021 05:02 AM
Scott B
10-24-2015 01:29 PM
Dicque
09-19-2015 12:53 PM
