Alternator R&R 2003 xtype 2.5l - RESOLVED
Hey guys I have the car on the lift right now and im not sure the best way to get the alternator out any suggestions would be great looked through here and cant seem to find complete instruction thanks !
Last edited by GGG; 09-09-2013 at 07:56 AM. Reason: Add 'RESOLVED' to thread title
Welcome to the forum bal150,
I've moved your question from General Tech Help section to X-Type section for advice from members with the same model as you have.
JTIS (Jaguar technical Information System) gives first removing the A/C Compressor as part of the procedure! The guys here must have found a way round that.
bal150 (09-07-2013)
https://www.jaguarforums.com/forum/x...replace-34499/
Hi Bal150, I hope this helps you?
And a big welcome to the forum, the guys and gals are sure to help you out as they have done for myself! It may be a good idea to thank those who point you in the right direction too! Thermo has a few post in this thread you can click on!
Good luck Chum! Stu
Good luck Chum! Stu
bal150 (09-07-2013)
bal150 (09-07-2013)
Replacing the alternator in an X-Type
Hi Bal150, this is the guide I stole from the jag co uk website, hope it helps?
Best Regards, Stu
Best Regards, Stu
bal150 (09-07-2013)
I read and reread that thread (how to change the alternator from above without removing ac compressor) and nearly attempted the job but the bit about flexing the radiator fan housing just drained my already modest reservoir of courage so I coughed up 2.5hrs labour at the local mechanic to do the job and got the ac system recharged while I (they) were at it.
Of note, this my second replacement alternator. I,m fairly sure the first had a limited life because the cables were bad but were not replaced. Not sure but either way, they are a known weak link in the electrical system when they age so you may want to consider new ones. I replaced them myself this time and hopefully this alternator will. Last more than 2 years.
Good. Luck! Post how you go.
bal150 (09-07-2013)
The shortcut method of removal from above is covered in post #5. For comparison and completeness, here's the JTIS procedure:
1. AC Compressor Removal & Refit:
JTIS - X TYPE AC Compressor.pdf
2. Alternator Removal & Refit:
JTIS - X TYPE Alternator.pdf
It sounds like they started with the alternator and built the car round it. What a pain to replace!
The following 3 users liked this post by GGG:
Follow up on the alternator r&r
I would first like to say thank you to everyone who responded to my distress call!!I had to remove the air box ,serp belt,compressor,then alternator,also replaced the cables,and the plastic thermostat pipe. it was very brittle.Iwas going to go the fan route but not much room to get it out didn't want to break anything.the whole job took me about three hours and I repair cars for a living,just never had to do one of these,thanks again guys!!
The following 2 users liked this post by bal150:
Danny A Fish (09-09-2013),
GGG (09-09-2013)
summerwind4 (09-21-2013)
The following 2 users liked this post by Danny A Fish:
JimC64 (09-09-2013),
3jagfamily
10-01-2015 01:49 AM
SoCalJagS
09-27-2015 09:20 AM
