Amber engine warning light.
On motorway today and suddenly felt a 'thump' followed by the engine power reducing and stuttering. Slowed right down and came off at the next exit. Switched the engine off and got the handbook out. States the waring light indicates an engine problem and has put the engine in 'limp home mode ! '. We decide that we would 'limp' home and drove slowly the remainder of the journey not going above 60mph. The car seems to be running as smoothly as it was before but the warning light is still on. Nothing obvious in the engine bay (oil etc) but i'm no mechanic. All the oil/coolant levels are fine. Any idea's anyone ?
ta in advance.
2002 2 ltr X type manual.
ta in advance.
You can have the codes read @ most auto stores for free...that is the first step. We need to know what the fault codes are.
I suggest buying a code reader to keep in the car...u don't need an expensive one...spend around $30-$60. Its an important tool to own..even if u don't work on the car yourself.
Get the codes and post back with them
X-series 2002 auto AWD 2.5 Petrol 66,000 miles on going problem for 3 months {jag/trained mechanic unable to resolve} all the usual replacement done sensors etc both banks fuel injectors /engine decarb/internal combustion chamber cleaning infold manifoldEngine warning light /with occasional amber which comes on driving around 70 mph stays on for a few miles then does not come on again until parked and journey resumed after same type drive as above......very occasionally accelerator resisting pressure of my footCODES P0170 PO174 CLEARED 4 TIMES.... COME BACK ON AFTER DRIVING AS ABOVE!.. ANY THOUGHTS APPRECIATED1
99xk8guy
06-05-2023 06:28 AM
RoyLittle0
05-25-2023 02:38 AM
