Any headlight assembly internals suppliers??
Before I go to the trouble of taking my headlamp assemblies out of the car to attempt repairing them, I would like to know if it is possible to get some of the parts beforehand. I bought the car a couple of months ago, and initally, while the low beams are adjusted okay, the highs are out of line. I tried to get them right, but apparently the innerds are broken. I replaced the high beams with 100w bulbs, and noticed the inner assembly for both sides' headlights are loose (even before I replaced the bulbs). I don't want to risk losing the current low beam alignment by taking the headlamps out of the car to inspect them on the bench, or am I okay to at least take them out without disrupting their innerds?? Does some other less expensive option exist for new parts, such as Suzuki, or similar?? ( I mean just to supply inner adjuster or mounting parts??) Thanks all
You should check it with our vendors , they should have the item you described
NALLEY
JPAM
ebay as usual
off the site
www.jagbits.com
www.motorcarsltd.com
NALLEY
JPAM
ebay as usual
off the site
www.jagbits.com
Kassaq (03-25-2011)
there is one guy on ebay that sells the little plastic pivots, he is in Australia.
He puts a little mighty putty epoxy around them to reinforce them, and sells them for 85 dollars... kinda pricey for a teeny part of plastic. but he is the only one with the little part.
I decided to re-do mine without the parts, I rebuilt them using a round headed screw that fit prefectly into the socket.... then built it up with mighty putty and some metal bits to make it work... been good for a few months now
Kassaq (03-25-2011)
Hey there Wasilla Alaska (home of Palin the Impaler) - when you do the repair, howzabout posting some pictures or a how-to?
I need to do this, and I've been putting it off becuase of the cost of the Aussie part at $85 per light, and Moto's not much better at $75 (but at least it doesn't look like a PLASTIC part for $75!). I also can't quite picture where that part is or what it does without taking everything apart, and i'td be nice to see what i'm getting into first....
Tanks in advance!
FS[NorthWest]: XJ8 / XJR 3" Mina Gallery Intake Pipe only (For X308)
xjrjag
10-12-2015 03:16 PM
n2audio
17
10-09-2015 10:53 PM
