Any write up on changing brake pads?
Old 05-09-2007, 10:28 AM
Humy's Avatar
Default Any write up on changing brake pads?
Heard the pad whistle in the X last night, looks like it is time. Any write up anywhere? What size rachets and wrenchs will I need?
I have done the pads in my Vette, it is very easy...
1) Lift and take off wheels
2) Take off bolt on bottom and back of caliper.
3) Swing caliper upward.
4) Remove some brake fluid from reservoir.
5) C-clamp pistons in.
6) Brake pads slide right out.
7) Clean off brake dust, and put in new pads.
8) Swing caliper back down and bolt in.
9) Press brake halfway, wait a bit, and keep doing till firm brake is felt.
10) Fill brake fluid back up and you are done.
Thanks guys
Old 05-09-2007, 10:47 AM
bigdreams05's Avatar
Default RE: Any write up on changing brake pads?
If you decide to do your rears as well, then you'll have to twist the caliper back in, but as for the write up you did, Few could put it better!
Old 05-09-2007, 11:55 AM
Humy's Avatar
do you know what size tools I am going to need? rachet heads for socket wrenchand free standing wrenches?
Old 05-09-2007, 12:01 PM
nineball's Avatar
no, but i can tell you the rear has one that is threaded clockwise and one counterclockwise.
Old 05-09-2007, 12:07 PM
If I remember correctly, it was a 14mm socket and I'd use the 1/4 inch socket for more strength! I think to take off the wheel, I don't need to tell you what socket to use. Other than that, I think that you're set!
Old 05-09-2007, 03:01 PM
13mm? Oh well, I guess I was off by a smidge!
Old 05-09-2007, 05:13 PM
Envy337's Avatar
Rears are also 13's. 10mm for the dampner nut.
Old 05-09-2007, 06:16 PM
04Xtype's Avatar
when changing the rear pads, i beleive you have to disconnect the e-brake cable
Old 05-09-2007, 11:17 PM
Taking the e brake cable off is a sinch, but you'll need plyers to pull the cable back!
Old 05-09-2007, 11:27 PM
04Xtype's Avatar
yeh it is easy, just remember to take the clip that holds it in off and then remember to put it back when ure done
Old 05-10-2007, 01:21 PM
Humy's Avatar
ORIGINAL: 04XTYPE
where do I find this cable and how doI disconnect it - is it a must that I disconnect this cable?
Old 05-10-2007, 01:27 PM
It's the one that you'll see attached to spring-like apparatus on the rear brakes only!
Old 05-10-2007, 04:57 PM
Envy337's Avatar
You do not have to disconnect the rear e-brake.
Old 05-10-2007, 04:58 PM
racerx82's Avatar
I don't recall disconnecting it....it's a fairly easy job...providing you're mechanically inclined....
Old 05-10-2007, 06:10 PM
04Xtype's Avatar
when i did mine i was reading the Jtis manual, and it sait to disconnect the e-barke cable, dont really know if it made any difference, but just did it anyways coss it was easy to do. and plus i didnt know if not doing it wud make any difference
Old 05-10-2007, 06:11 PM
racerx82's Avatar
Na, now that i think about it..i didn't disconnect mine.....but i suppose if you're a first timer...can't hurt...
Old 05-10-2007, 06:14 PM
04Xtype's Avatar
Yeah it was the first time i dod it on the X, when i did it on a Vdub aand an Audi i didnt have to disconnect the cable, but like u say, cant really hurt.
Old 05-11-2007, 12:27 AM
Well, I disconnected it, but I couldn't get the caliper to twist back in...and I'm more than mechanically inclined!
Quick Reply: Any write up on changing brake pads?
