Any write up on changing brake pads?
Remove the caliper and caliper bracket (2 15mm bolts). The rotors might have some metal clips on the wheel lug studs, remove them with a pair of dikes. If the rotors don't come off easy after you remove the clips, hit it with a hammer. Pretty easy.
I did one a while ago, but i'll give you my short unadulterated version.
I call it the turkey gravity bleeding system: (if you're doing it yourself)
First, I've heard stories that you can run the break fluid back up through the reservoir when you compress the calipers piston.
I don't recommend this and i have never done it since you will be forcing the fluid through the seals that let fluid only go one way...
Second, my method is to suck the fluid out through the reservoir using some sort of turkey baster/syringe..or a hand held vacuum pump
Once you suck it all out, top it off and your good to go....so they say, but that leaves the old fluid still in the lines. If you do it that way, at least open the bleeder valve for a minute or two to let the old stuff out....via gravity. Start with the right rear and work your way around to the front. Open one bleeder valve at a time. Make sure you keep topping off the reservoir and don't let it go dry.
Approx time 20-30 minutes. Use Dot 4 brake fluid.
trosty
26
12-18-2022 06:40 PM
