Anyone know how to polish chrome?!
the "chrome" around the windows is really aluminum. It can be polished with mothers aluminum polish. The bumpers should be polished with mothers chrome polish. You can get either at your local auto parts store.
They will have directions on how to use them I would also get some micro fiber cloths. They should be polished every time you wash the car.
Side Tip: Use the mothers aluminum polish and a piece of steel wool on your tail pipes, they will Bling like you never thought they could. DO NOT USE STEEL WOOL ANY ANY OTHER PART OF THE CAR EXCEPT THE TAIL PIPES!!!
For chrome pieces, you could also try a little bit of diet cola and aluminum foil. Sounds crazy I know, but these guys claim it works wonders: http://www.instructables.com/id/Chro...busters-Style/
Don't know how well it works (or if it works at all) on aluminum pieces, so try it on your window trip at your own peril!
the diet cola does have an acidic value so don't let it sit on the paint.
Autosol (Mothers, Blue Magic, etc.) and some fine steel wool does wonders on chrome tips, but I would skip the steel wool on the trim brightwork. Sometimes it's chrome covered plastic, so you have to be careful. I don't think they used chromed plastic on the X but I'm not 100% sure.
If you use a dremel, hopefully you have a variable speed model. Start with the slowest speed and the lightest cut buffing wheel you have - foam would be great if you had it. Start with too high an RPM and you could burn through the finish. If you have a cloth buff, you could take some jewler's rogue to it. It can be a pain to get the buff loaded up though.
