Arm Rest Creaking Driving me nuts!
Has anyone had the same experience and found a solution?
The arm rest in my Xtype is creaking. It even creaks when I don't have my elbow on it and when I do it sounds like a container of styrofoam moving around. It is really annoying. I'm driving an 04 xtype 2.5 litre manual. The arm rest opens in two spots and the top slides forward for comfort.
I have tried to use some weather stripping in between the areas that open and close...but it has not helped.
Any suggestions?
Any suggestions?
Duuuuuuuuuuuuuuuuuuuude....i was about to post the same exact thing the other day!!! Mine does the same thing. But for now im with 04XTYPE and just turn the radio up!! LOL. But yea its beyond annoying. Im a person that must have an arm rested on something too. So ill be checkin this post for help also!
I found a post on a UK forum that I am going to try today. In addition I am going to see if my mechanic has a torque screwdriver that I could borrow to tighten the various parts.
"Stopped mine creaking by using velcro, no i haven't stuck it shut. I've stuck the cloth side of it onto the bit that shuts so that instead of plastic rubbing on plastic, it rubs on cloth. Also stopped my glovebox making a noise.
Was told about using velcro to stop rattles and squeaks by my brother, a senior technician at bmw, apparently that's a bmw approved way of stopping squeaks"
I will let you know how it works out....
According to the mechanic there are no torque screws to be tightened. The whole thing is held together with rivetts.
So, I velcro'd the whole thing with just the fuzzy part and I must say that it has improved the situation by at least 80%. It has gone from annoying to just creaking once in a while.
I hope you guys have the same positive outcome. I did use a lot of velcro and cut out little squares where the rubber knobs connect so that it still closes properly.
Cheers.
Cheers.
Cheers.
Cheers.
al_roethlisberger
09-11-2015 10:04 PM
FS[Western US]: XJS Wiper Motor Upgrade- 76-88 - Electrolux Style
XJsc-guy
09-02-2015 11:43 AM
