auto gearbox trouble
help can anybody help i have just repaired my autobox and put it back in the car i have changed all the clutches o rings new piston and now it tries to drive forward all the time no reverse no neutral and when i select reverse there is a harsh lurch forward can any one tell me what i could have done wrong
hi all i have found the problem i had to take geargox back out again and i found when i put the valve block back on i hadn't located it on the manual selector shaft so it was pumping oil to the forward clutch all the time put it all back together and put it back in my car and i have drive neutral and reverse only tested it in the carpark so far will take it to my local gearbox shop and they will do a full test on it and hope everything will be ok
Wolfy
05-28-2024 08:06 AM
