auto leveling light jammed
Old 09-05-2009 | 11:04 PM
ghettomike's Avatar
Default auto leveling light jammed
the auto leveling light seems to be jammed on the driver side, i dont see anything in there that is causing this,,does not appear to be hung up on anything..is there a leveling manual adjustnemt? \im thinking if there is and i adjust it it may un-jam it.
Old 09-06-2009 | 12:51 AM
Green Machine's Avatar
Smile
If it's not too far off, there are adjusting screws accessible through the bar above the headlights to adjust the light up or down. I have the same problem and my left side light. It quit working several months ago and I did a manual leveling on it with no problem. Now that light it's just like most other cars that aren't self leveling. The right side one still levels automatically.
Old 09-06-2009 | 09:30 AM
ghettomike's Avatar
it still makes a noise as if it is attempting to autolevel...this is why i say jammed and not a dead motor or other electrical issue.
does yours do this as well or is it quiet?
im probably just gonna try the manual adjustment, if it frees it up great...if not ill just aim it.
most (not all) higher end cars with HID's have some sort of leveling feature. my CTS has load leveling rear suspension to keep the lights aimed at the same height, this also helps the ride when you add heavier items in the trunk or more people in the car.
Old 09-06-2009 | 09:07 PM
Question
It did seem to click a little when it first stopped working but now it's silent. I don't know if it was just my imagination or if there actually was a clicking sound coming from the leveling mechanism but there's nothing now.
It's certainly a lot cheaper to manually adjust it if possible than to replace the auto adjusting mechanism. As far as I'm concerned on mine as long as the headlight is still working manually I'm just going to leave it alone.
Wolfy
05-28-2024 09:06 AM
Jpav27
07-31-2022 07:43 AM
WinterJag
16
10-09-2015 08:49 PM
rsa760041
23
09-25-2015 02:33 PM
pnwrs2000
09-03-2015 12:55 PM
Quick Reply: auto leveling light jammed
