Automatic Trans filter repalcement How to
I've read so many threads on this but no one answers the question to the point.
1. How to Chang the filter, cause there is one.
2. How many quarts of trans fluid is needed.
I promise to post a you tube video as soon as I do this. To many vage answers
From another thread
There is no pan on our transmissions. What is referred to as a filter is internal, needing disassembly of the transmission, to change or clean, and only catches big chunks, which came out with the flush.
https://www.jaguarforums.com/forum/x...ure-faq-43649/
https://www.jaguarforums.com/forum/x...change-152548/
Any help?
Any help?
Received 3,887 Likes
Thermo, there's what looks to me like a transmission pan mounted on side of the transmission near the radiator. It's fastened to tranny by approx 14-16 10mm machine screws (need to get a decent picture of it). I'm used to seeing the pan mounted horizontally on bottom of transmission. Know what this is?
swingwing (10-26-2016)
I understand that the Jaguar approved method of ATF change is to drain the ATF out ( expect about a third of the total contents) refill, run through the gears to circulate the ATF, repeat the process once more and pay for the work/ATF.
When I change my ATF fluid I intend to find a company that has an automated unit to exchange all ( 98% ) of the fluid.
These operate in a " dialysis" way. When connected to the car, the cars ATF pump does all the work and pumps out the old dirty fluid which is automatically replaced.
No excessive pressure used and you can see the old contents change colour during the process.
I am not sure which brands of such devices are available in the USA.
Youtube has some demos of such equipment.
