Aux port kit for '04 X-Type
I noticed that Jaguar dealerships offer a module which fits inside the center console and the cost of like $400. I've also seen online electronic companies (Crutchfield, etc.) off double din replacement stereos (with AUX ports) that come with free install kits for the X-Type. Are there any other options? The dealership option seems great but pretty expensive. The replacement stereo would function great but how would the dashboard look. I might seem picky but I like it when the dashboard looks proper. A glossy black stereo with pulsing lights just doesn't fit my vision of a proper Jag. I've tried the FM transmitters that plug directly into the antennae jack and wasn't really impressed (with a previous SAAB). Just wondering if you've all found a great economical option for getting MP3 audio in your Jag.
Thanks.
Thanks.
Yeah, the OEM solution is the ACM, Audio Connectivity Module. A few sometimes make it to eBay, but they are expensive there as well. Also yeah, I too dislike flashing glossy headunits that look like alien training shoes having sex in a rave party.
If you have a tape deck, you can simply solder an AUX-IN lead to it. The mod supposedly provides a "CD-quality input", from what I can tell it is at least far superior to the (wireless) FM transmitters tried and the cassette adapters I used before, and I've been perfectly happy listening to it ever since.
How-To: DIY headunit hack for AUX-IN (on tape deck).
Photo/Link/Info Request - Aftermarket Headunits & AUX in Options
newtojags (05-22-2014)
The issue with the CD changer approach is that it's a proprietary and fairly uncommon fibre optic network. It's practically impossible to tap into it.
Thus far, I reckon these are the options, somewhat from best to worst:
- Jaguar Audio Connectivity Module which "replaces" the CD changer, though there is a switch to select between the two.
- The AUX-IN mod for the tape deck, which provides CD-quality input from practically audio device.
- The iSimpli and the lot, which are FM modulators and hook into the radio antenna.
- Parrot MKi9000/9100/9200, which basically overrides the head unit itself and functions as an mp3 player.
- A cassette adapter for tape deck.
- FM transmitter (the two I tried were hopeless).
The AUX-IN mod is rather simple to do if you can solder. Seriously, if you want to keep the centre console stock-looking, get a 2nd hand tape deck from eBay and just try the mod.
Hi,
I've been trying to reverse engineer the CD-model to find a cheap solution to the missing AUX-in. However, after looking at schematics of the ICs (the "brain" SAA7706H see any PDF) and measuring on the actual unit with a oscillioscope, these are my findings
- even though the IC supports analouge inputs, the CD-version of this radio does not use any of the analouge inputs. Therefore you cannot simple add some RCA socket. Instead there are 2 possible hack-modifcation scenarios of which neither is cheap nor easy
a) you change the User Interface buttons, and re-wire so the analogue inputs can be selected
b) you add an A/D conversion and feed it into the I2C bus directly
By looking at the Electrical Guide for X400, your other option is to "build" your own ACM module, either by re-using a BOF (D2B) phone module or Voice Activation control module (but it might be complicated since they are not default in stereo). Potentially you could also reverse engineer the ACM, since the CD-changer also would require A/D conversion, but then I think it is easier to actual buy a new headunit (with aux and bluetooth) and create a fancy connection to either a (2nd hand) stationary phone or tablet. This will give you a much better and cheaper solution than the ACM unit.
That's my conclusions so far...so I will most likely go for a 1-DIN Headunit with BT and connect a 7-8" tablet to it for navigation, reverse-cam, ODB2 connection and anything else you would like to add ;-). By rooting the tablet/phone and installing apps like CarHome Ultra + the Headunit manufacturers controlling app you can get top sound quality + android capabilities at a very low price, at the cost of losing the original look. If that is a showstopper, I guess ACM is still the best option.
That's the road I think I will be taking - buying a Pioneer MVH-X580DAB on sale and adding a 2nd hand tablet and usb cam.
Comments on this?
/Magnus
Comments on this?
/Magnus
