AWD Question {Can you...}
Received 3,907 Likes
David, that is a loaded question. With the early X-Types, it would be possible as the viscous coupling would then redirect all the power to the front wheels. But, the later cars with the improved transfer case, it would essentially result in the car being in neutral all the time as all the power would be sent to the shaft that has been disconnected.
The other thing you need to keep in mind is that you are going to have to leave the CV shafts in the rear wheels as the bearings are not meant to not have that shaft there. The shaft helps provide some of the side to side support of the bearing. If you take out the CV shaft, the bearing will have a very short life. You would then have to find new spindles to replace what is in the rear to make the car a true FWD vehicle and not have all the power train loss still.
David12345 (10-12-2016)
themorningman
01-22-2017 11:02 AM
powerhouse
08-30-2016 01:23 PM
rainbowboy
08-29-2016 10:27 AM
