AWD in reverse?
>the handbrake trick...
Can you say a little more about that trick?
If the wheels are spinning when do you pull up on the E-Brake, while the
wheels are spinning or before stepping on the gas?
Jaguar: Grace, Pace, and Space - Sir William Lyons
What year is your Jag?
After 2004 they switched to an open differential setup that was pretty much useless. It wouldn't transfer power to the front wheels unless you pulled the ebrake creating resistance in the rear and forcing the power to the front.
Before 2004 there was a much better performing (althought reliability was questionable) viscous coupling. Power would transfer between axles naturally in this setup.
