AWD thumping noise question
If it were me (socket set and some torque wrenches) I would replace the cv myself. To test if it is indeed the cv axle or not though, you should make sharp turns under moderate power and see if it starts clicking or clunking. If not, you might want to wait on the cv replacement because normally that is the tell-tale sign of a worn cv axle. If you look up on youtube how to replace a cv axle, it will essentially be the same for most cars (bolts just in different locations.) Also, if you haven't already, the JTIS is very helpful for doing work like this.
Bdg6065 (11-13-2012)
Thang Nguyen
10-12-2015 01:25 AM
James007
09-06-2015 06:47 PM
