Bad Sensor
![Question](https://www.jaguarforums.com/forum/images/icons/icon5.gif)
My 2004 3.0 X-Type is diagnosed with a bad fuel sensor. It's been impossible to locate what I need from any auto parts store. I finally found one in a junk yard and had it installed but the same issue occurs "engine sputters when I first take off but stops when it goes into higher gears".
I could sure use some advice....?
Welcome to the forum Clay,
I've moved your question from Jaguar Forums Feedback & Suggestion Center to X-Type forum. The Feedback & Suggestion Center is for posts about the forum and not for technical questions. Members here with the same model will be able to help.
Need more information here. What do you mean by fuel sensor? Is Check Engine light on? If so then you need to know what code(s) tripped it. Your local auto parts store will read the OBD codes for you free. How many miles on your car, and when's last time the fuel filter was changed?
When you say "thats what the code says" are you reading the information from the X-400 DTC code list? Or is that what the code reader gave you for a definition?
In order to help we would need the actual code number. The generics from code readers is most cases don't relate to Jaguar DTC Codes. Please post the actual code number and we will give it a whirl.
FS[Western US]: Parting out 1997 XK8 convertible
BobRoy
49
09-18-2016 10:48 AM
Florida_Pilot
08-25-2016 11:44 AM
11-30-2006 11:15 AM
