bad water pump
Received 3,907 Likes
mobile, if you can rotate your tires, you can do a water pump on this car. LIke was mentioned, you need to remove the battery. Then you lift up on the tensioner and slide the belt off. From there, you undo 4 bolts holding the pulley to the water pump. Finally you undo like 8 bolts and the pump is ready to be removed. Install is the reverse process.
After you do it, you will be questioning why you waited so long because it is so easy. I put it right up there as being easier to do that a water pump on a late 70's RWD car with no emissions stuff on it.
1964Daimler
09-09-2015 11:28 AM
02, 2002, 25, bad, jaguar, jaguar x-type, like, manual, pump, replace, replacement, type, water, water pump, xtype
