Battery Cables
Battery Cables
I need to replace the negative (and probably the positive) battery cable. The ones in the auto shops are too short. I see on Ebay that they run anywhere from $60-$130. What should I look for when ordering? Is there a place that you can suggest? I have a 2003 X-Type AWD with about 154,000 that I'm trying to bring up to speed. Thanks.
Received 3,887 Likes
Thantzar, if you look at "Jaguarparts.com" (dealership out of Cleveland OH as I recall), they have both cables for $65 each. If you call up JPLV (sponsor here), they can probably get you them slightly cheaper than that and get you OEM parts. Most guys simply pull the cables off and go to the auto parts store and find a set that is close and buy those.
Lcgi (05-29-2017)
