Battery discharge time when parked up
How long can you leave your X-Type parked up before the battery goes flat?
I don't have any additional equipment fitted that would bleed the battery.
I am finding that the battery is flat if I leave it for 10 days without taking it out and that is on a battery that was replaced last year.
The maintenance guy says that is normal but I am not sure if they are just avoiding replacing under warranty.
Received 2,190 Likes
Thats not normal and i would suspect you have bad battery cables, common x type issue. And the battery is nver fully charge, it goes to a voltage range that wakes up the cars electrical system and runs the battery down the rest of the way. And every time you run a battery down you effectively kill have of its reserve power. Do voltage drops on the cables when hot and or get a battery tender and dont worry about it anymore. Thyere cheap $30-40 and youll always have a fully charged battery
Bob OB (04-15-2020)
Charlene n John
09-28-2015 06:01 AM
MC36
US Lower Atlantic
09-01-2015 07:34 PM
