Battery light symbol
A common problem for the x-type is the battery cable corrosion.
First remove and clean the cable connections at the battery, Examine the Positive cable for corrosion along the wire strands. They are prone to corrosion inside the cable.
Next remove and clean the opposite end of the cables. Remove from the starter and polish and tighten. The ground is underneath the battery mount.
This if the alternator is good and the battery is good should solve your light issue.
bambea1
04-28-2019 03:39 PM
TristanC
11-23-2011 05:18 PM
Trick Freestones
XJ40 ( XJ81 )
05-15-2011 11:43 PM
