Battery questions?
02 X-type
Needs a new battery. I have been looking at batteries and found that the Duralast and Interstate batteries look exactly like the original Jaguar one, same handles and everything. So I am assuming that Interstate and or Duralast supply Jaguar the batteries with a private label. My guess is Duralast is an Interstate battery labeled for Autozone.
What other options do I have? It seems that batteries for these cars are hard to find. Exide list one but there are no dealers close. What did you replace yours with and what was the cost?
I had trouble finding a battery for mine as well. No luck with Sears, but AutoZone had one in stock that was the right size. It was a Duralast, and normally I try to avoid that brand of parts, but it's held up great over the past 18 months. It was a bit pricey though, at $120.
ORIGINAL: 310jag
ORIGINAL: tokaygecko
Wow- $120 for a Duralast? Thats expensive. I got a facotry Jaguar battery from Jaguar of Rockville, MD for $124.xx. Definately worth the extra $5 for a factory battery.
ORIGINAL: 310jag
The Duralast has a 3 year replacement and 8 year pro rating. I don't think Jaguar would do that. I also got the 94r-drl, I think that is the number, It has more CCA then the stock battery as well. [8D]
Guest
Posts: n/a
my factory battery was by VARTA, the dealer replacement that I just got was an Interstate that looks almost identical.
The X-Type is a fairly electronic car and the charging system is more complicated than many other cars. there is even a temperature sensor on the battery housing to help manage proper charging. I dont doubt that your car has been working fine for a year but technically, the cover should be on for the system to work its best.
there is no temperature sensor on the battery box.. that's just a place to plug the plug in.. originally the cars come with a transit relay on the batteryand the connector plugs into it.. keeping certain circuits able to get power. so the battery does not die... while shipping the car.
I bought a deca battery...the only place that had a battery to fit and I think I paid either 110-120...worked great for me sine than...As others have said I wouldn't want to increase the battery size or anything just because the electrical systems in these cars are too expensive to fix...
Guest
Posts: n/a
Hello, I just replaced my battery tonight in my 02 x-type with an Interstatebattery MTP-H7 (85 months) that is made for Jaguar. It fits perfect and mirrors the Original battery. I reapplied the foam insulator from the old battery and reused the vent tube. Jag dealers wanted $141 to 171 for Jag bat and I paid $130 and save gas since dealer is an hour drive from me.If this helps you need one go to the http://www.interstatebatteries.com/estore/and you can find a distributor.
J
2002 3.0 X-Type SE
J
2002 3.0 X-Type SE
Guy-Pierre Boucher
09-16-2015 05:55 PM
