Beeping noise
Easiest way to check though is when mine goes off for the freezing it shows the temp in the message center on the dash.
Adam Lueb (09-03-2011)
![Smile](https://www.jaguarforums.com/forum/images/icons/icon7.gif)
I know mine beeps when the temp is just above freezing. I'm on the west coast of Canada so although we've hit the 80s a couple of times I've never heard the beep then.
I think I used to be one of the strongest Jag supporters here. I honestly cant wait to get rid of the car.
Its the air refresh button. It starts off in the on position, then about 5 minutes later it turns off and beeps. You don't know it does it, because the light shuts off leaving you with a mystery sound. Note that it doesn't always do this. It picks and chooses when it goes on and off.
I wish all I had to deal with are beeps. My car has gone completely insane. I press the brake pedal hard and it goes into engine system, gearbox and dcs failures. No gas petal, revs go to 2K. But wont throw a code. Turn off then back on and it's fine until I stomp the brake pedal. This weekend I was fooling around and got it to do it with the motor off and in park. I want to drive it off a cliff.
Yes, the recirculate button. Thats the culprit. It decides on its own when to recirculate, then when it shuts off, again on its own, it makes a beep that appears out of nowhere. it drove me nuts for weeks trying to find what was beeping. I actually had to stare at the dash and pay attention to figure it out.
Your correct the recirculate button has a mind of its own when it comes on, when you first turn on the HVAC you can press the button or if it is hot enough it will come on by itself. First car I had that this function worked that way. Perhaps that's what I am hearing. It has been cooler the last couple of days as it has rained between Irene and this other storm off the coast for about 8 days, so the temps have only been in the 70's maybe hitting 80. But I haven't heard the button going off. Today it is only going to hit 78 or so, I bet I don't hear it.
![Icon Speaker1](https://www.jaguarforums.com/forum/images/smilies/icon_speaker1.gif)
baskervillema
10-01-2015 06:43 PM
UKnFor-dluv-expat
09-26-2015 08:40 PM
