Best X Type Struts
Hey guys,
So I installed H&R sport springs about 8 or so months ago and I've noticed that my rear struts have become more and more bouncy over time.
I'm pretty sure at this point they are blown, so I need new one.
I still want to run my H&R springs so I want the best shock I can get that wont blow out like my stock ones did.
How are the bilstein heavy duty shocks?
Received 3,884 Likes
JaggyX, when looking at shocks, make sure to tell them that you need to sport edition shocks, not the standard X-Type shocks. The Sport Edition shocks are just a fraction of an inch shorter to accommodate the dropped springs included with the sport model. They should also be a little bit firmer than the factory shocks you had.
As for what brand is better, can't speak for that. If Bilstien sells shocks for our X's, I would go with them. I know the guys in my truck club that are using them love them. Sure, they cost a little bit more, but they also perform like they cost.
The "comfort" style I believe is the "standard".You want the "sport" like he already said. Its really hard to find out how far its been dropped truely and what shock accommodates it.
hmm well I'm a little hesitant to buy those then. My car is lower than the sport model as you can see in my signature picture. My only option really is to buy those and see what happen. Is there any way I can make those bilstein stiffer or install aftermarket bump stops so they don't blow out the new shocks?
I really don't think I'm in need for new shocks. My car doesn't jump and down when I'm driving... I'm experiencing more of a front end "knock" and "squeek"... Thinking more around bushings and control arms more than shocks... It what tire kingdom told me but their speciality is tires not suspension... I've had my control arms, bushings n sway bars replaced by jag over a year ago under warranty but I still experienced the noise just not as bad and like all dealerships claim they tried to pass it off as normal... Maybe they are going bad again?
One shop told me test my shocks by pushing down on the end of my car n if I bounces back a few times than it's my shocks but I did that m when I let go it does one full bounce... Doesn't keep bouncing... As I stated above I'm experiencing more front en knocks n squeeks and not seeing the car bouncing around up n down on the road...
Knocks and squeekes are usually ball joints and tie rods. But if you have had them changed recently, the arms come with new ball joints. Tie rod ends also cause play and some noise too. What you could do is, jack up the car on one side and grab the wheel at the 9 and 3 o'clock position and try to wiggle the wheel side to side ( right arm in, left arm out type motion ). If you have any movement its the tie rods. You can then while the car is lifted and hopefully supported take a somehwhat long pry bar or some sort and put it under the tire and lift it up and down and see if there is any play in the ball joints. EVERYTHING should be TIGHT. If thats all good...turn the radio up louder. LOL
