A big thank you to all of you!
I recently had an issue with my 05 X-Type when it wouldn't pass the emmissions test. The guy at the shop said my brake booster needed replacing and it would be a minimum of $600.
That's when I started to read. Thanks to you guys and your detailed postings, I figured out I had a vacuum leak. I replaced the brake booster line, then cleaned the MAF sensor, and in the end I had to replace the IMT valve o-rings (which I did myself) - and Voila!
Not bad for a girl, huh?
I couldn't have done the first thing without you guys!
Bobbi
Bobbi
Received 3,889 Likes
