black smoke
Received 2,670 Likes
3 general causes of black smoke on a diesel:
-Injection pressure is too low
-Air leak- not enough air getting to the combustion chamber- this could be boost system related also
-Too much EGR being used for some reason
I don't know the specific idiosyncracies of the 2.2 litre diesel in the X type
Another very common oriblem (with excessive black smoke as a by product) is dirty and sticking turbo. See link and read all the links in the posts.
https://www.jaguarforums.com/forum/x...-turbo-189592/
Hi. Might not be the same problem but I had this with a PUG diesel and the cure was to put a fuel system cleaner in the tank and take the revs up to the limiter for e short while. (lots of smoke) every couple of days. This cured my car. If yours is an auto you may have a DPF filter and this could be your problem.
