Blank Navigation screen
#202
![Unhappy](https://www.jaguarforums.com/forum/images/icons/icon9.gif)
PM me your email address. I will send you a file. You need to burn it to DVD-R loose then start car, remove map dvd and insert the one you burned. Screen should say updating. If it doesnt, just let it run for 1o minutes, then cycle ignition. I hope it works. If not you likely need DVD reader.
#203
The cost of pressing the wrong button deliberately may be high. You can try a newer nav DVD but if that doesn't work will need to replace the nav module (it's in the nav drive).
hombre_101277 (11-24-2013)
#204
PLEASE help me out,,,, went in to hidden menu and by mistake i press the update menu, than stop the engine.When started the engine BLACK display, only music works now.PLease send me software if possible, !!!!!!!!!!! Just resolved the problem with lean codes on bank 1 and 2 and now look another problem on the jaggggggg......I feel like i want to give up guys ....
I hOpe it will work!!!! will keep you posted
#205
i will try with a new cd as one member will send me a file ...and said to me to burn it on a dvd r and take my map cd out than let it run for 10 mins so hope it will work....i pray it will because it is so embarrassing ,,, i just done works on my jag to ban 1 and 2 lean codes and now another problem with the jagggg
#206
Hi Guys , i have a jag s type R, a beauty of car but a pain in the same time.i went in to hidden menu holding the 2 buttons, than mistakenly press update button. error came "update can not be made due to no cd update" than i have stopped the engine.When turning back on screen completely black. no air con, no functions on nav screen and 50 51 error on small screen!!!!!!! i am about to give up ,,,just done lean codes bank and 2 and ow look ! another problem Please send me a software (not map) for s type r please!!!!!
#208
#209
This thread is getting more and more confusing, with folklore replacing fact and fact being ignored.
Firstly all the mis operations of pressing buttons and switching off the power CANNOT AND WILL NOT DAMAGE ANY OF THE HARDWARE. THE FAULT IS A SOFTWARE PROGRAMMING FAULT.
I have typed the same explanation until my fingers bled in trying to help whilst others offer the most outrageous remedies.
Mapping discs also contain the protocols for operating the screen and all the switchware associated with it, SO PLEASE GET YOURSELF A NEW MAPPING DISC AND FOLLOW THE INSTRUCTIONS I HAVE POSTED ONTO THIS THREAD NUMEROUS TIMES.
#210
Please please please help me with my black screen in my 2004 jag STR . I have by mistake pressed update button, nothing happened and I stopped the engine than blackk screen. So many trouble with this car!!!! Still trying to resolve bank 1 and 2 running lean , fuel trim over 10%....
#213
#214
To reload the operating systems.
turn on the ignition and remove the old disc from the satnav player turn off the ignition.
Start the engine ( the engine is kept running only to keep the battery charged) and insert the new disc DO NOT switch off the engine until the the leaping jaguar appears on the screen, normally 5 to 10 mins at this point all of the services will have been updated and the control of the heating, audio etc will have been re-established.
The last thing to load is the mapping info, make sure you select the right area of Europe as the default can be Poland and not England once you have selected England you are ready to go.
Best wishes Greytop
Best wishes Greytop
#215
Best wishes Greytop
Best wishes Greytop
If there is anything else that I may have to do please let me know!!!!! Thanks again
#216
Many thanks, for your info's , I am waiting for the 2006 DVD sat nav system to come (from eBay) and hope that I can get rid of the black screen and 50 51 error.will keep you posted.
and I will try tommorw to reload the system and get rid of Te black screen and hopefully use back the heating controls etc. If there is anything else that I may have to know please advise guys!!!
#217
All Done, the big cat is alive and ROARS 🆒, the new DVD software (Map) turn'it back to the jungle
Norri (11-29-2013)
#218
I need the software too, i am having the same 51, 50 errors. Can someone please help seansmitty42@gmail.com.
#219
Hi everyone, I have uploaded the LOADING.KWI file onto the forums on my other post.
This file burnt onto a REGULAR DVD-R fixed my 50 51 error and brought my entire unit back to life.
Here is the link to the other post https://www.jaguarforums.com/forum/s...072_1-a-51699/
Hope it helps, I know I almost pulled all my hair out trying to find an inexpensive solution.
Andy
Andy
#220
hi my name is paul iamthe woner of a 2003 x type in NJ i took my navigation cd out by mistake and insert the navigation cd from a landrover that i used to have before having the Jaguar. now my navigation screen is on off i took that cd out but nothing has change i don.t have the factory software and will ipreciate if you can share a copy of that software with me i am a technician i love this car and i want to fix this problem help me please my email is paul9088@msn.com my last 6 of the vin# D47471
