Blank Navigation screen
Old 04-20-2017, 04:21 AM
jag nutter's Avatar
jag tech. hope you can help
  #482
Old 04-21-2017, 02:15 AM
jag nutter's Avatar
Default jag nutter
Originally Posted by FactoryJaguarTech
Dont keep searching for s/w updates. That was the latest one. What you need is map DVD. I am in process of trying to find the 2008 disc. Will keep all posted.
hi i have x type jag 2l se blank screen problems, have tried battery disconnect
but no joy, probably need software can you send the link to
kenobe1949@yahoo.co.uk
many thanks in advance
jag nutter
  #483
Old 05-03-2017, 12:48 PM
Selfmade1's Avatar
I have a 2008 s-type and my screen is blank flashing a 50/51 code... Is there anyone that has any type of download they could possibly send me to fix this?
  #484
Old 05-05-2017, 07:45 AM
cwlwch's Avatar
Default Clean DVD
this may sound simple but try wiping the DVD clean. It's behind the panel on nearside of boot.
  #485
Old 05-09-2017, 03:35 AM
rosariosicilia's Avatar
Hi, I find the same problem I need the fil to re-screen the screen of my jaguar x type you could send to my email both the fil and the procedure for burning dvore rosarioacarrera72@gmail.com.
I'm in your hands for a week that oh all blocked.
  #486
Old 05-11-2017, 04:47 PM
FBD's Avatar
FBD
FBD is offline
PM me your email address. I will send you a file. You need to burn it to DVD-R loose then start car, remove map dvd and insert the one you burned. Screen should say updating. If it doesnt, just let it run for 1o minutes, then cycle ignition. I hope it works. If not you likely need DVD reader.
I know that this is an ancient thread, but does anyone have this software DVD file or know where I can get it? I have the exact same problem as the OP did.
  #487
Old 05-12-2017, 09:14 AM
Received 6,307 Likes on 5,495 Posts
  #488
Old 05-14-2017, 08:54 PM
Daniel Bautista Solis's Avatar
Default Did you ever figure this out
  #489
Old 05-15-2017, 08:11 AM
FBD's Avatar
FBD
FBD is offline
I still don't have it working. I've burned the LOADING.KWI onto 3 different disks, 2 dual-density each burned at a different speed, and one regular DVD. It just spins up for a few seconds and makes a couple of clicking sounds, then the disk just stops. Not sure if it doesn't know how to read the KWI file or if the DVD unit is just bad. My options are to either buy a 2011-2012 updated map disk which incorporates the KWI file, and/or buy another DVD unit. It's a bunch of money either way. I can pull the test screen up on the touchscreen unit, so I know that's not the problem.
  #490
Old 05-29-2017, 05:26 PM
Samgebeor55's Avatar
Originally Posted by Jagm1979
I have a few questions:
1. will this work with an 02 x type
2. does this have to be burned to a dual layer dvd. I just dragged and dropped on a sinlge layer disk. but did not work.
Could you please send me the file through E-mail juang444@aol.com
Thank you.
do u have the disk that i can use to get my screen back on its black now and says ext 50-51
  #491
Old 05-30-2017, 05:01 PM
FBD's Avatar
FBD
FBD is offline
Just to update, I eventually broke down and got a used DVD nav unit off of ebay, took out the old one, put this one in and just like that, all is right! Now I just need to get one of veffremovve's Bluetooth audio things to replace my CD changer in it will be like, modern.
  #492
Old 05-31-2017, 04:12 AM
Artur Anush's Avatar
Default Sos help
Friend I have the same problem. can you help me
Very much I ask a lot of thanks ......
  #493
Old 06-30-2017, 07:54 AM
waxmaster's Avatar
Hello everyone I am having the same issue with my XJ8 (x350). I need the file to burn to DVD to boot. Please send it to me if you have it, I would appreciate it. Thanks dmitriyreshetov@mail.ru
  #494
Old 06-30-2017, 08:08 AM
waxmaster's Avatar
Please Help! I have same problem with my Xj8 (X350) dmitriyreshetov@mail.ru
  #495
Old 08-06-2017, 11:51 AM
Jperalta's Avatar
Default jaguar x type Nav software
Originally Posted by solidx
No there is not change since this is for the device to load properly. To fix the boot sequence. Check to see how are you burning the file - I used a Verbatim Dual Layer DVD-R and the slowest speed - You can use PowerIso or MagicIso to burn the file loose.
do you have the update file to burn into DVD reader and fox blank screen? My email is sokerall@live.com
  #496
Old 09-04-2017, 04:45 PM
DIL's Avatar
DIL
DIL is offline
Default help for 2004 JAGUAR XJR
hey I have 2004 JAGUAR XJR I NEEDS software for radio (with NAV)LIKE EVERY ONE ELSE I PRESS WRONG BUTTON I CAN BURN THE
  #497
Old 09-04-2017, 06:16 PM
DIL's Avatar
DIL
DIL is offline
Default software
Originally Posted by DIL
hey I have 2004 JAGUAR XJR I NEEDS software for radio (with NAV)LIKE EVERY ONE ELSE I PRESS WRONG BUTTON I CAN BURN MY EMAIL IS dilpreetsa8@yahoo.ca
sofl
  #498
Old 09-28-2017, 05:25 PM
chrystalc's Avatar
Default Navigation went black error code 50 51
Does anybody have that file to put into the DVD system so that way I can get mine running to mine went black then error code came up as EXT 5051 so if anybody can help me and send me that file I would appreciate it very much my email is chrystal.chafey@iCloud.com my phone Number is 949-813-7348 you can send it either way I would appreciate it I really need that also what do I put it on a regular disk or a dual seven days my jag is a 2000 6 S type???
  #499
Old 10-16-2017, 02:22 PM
Anagnostis's Avatar
hello.
i have the same problem, accidently pressed the s/w button and my screen is totaly black. please help!!
  #500
Old 10-16-2017, 03:04 PM
Aademaki's Avatar
Originally Posted by Anagnostis
hello.
Hey bro I fixed it!!!. I bought a new or used jaguar navigation DVD drive from eBay for $150. Removed the old one and put the new one and boom it came back on. My jaguar is an s type 2005 tho. So you have to look for your own year on eBay . Easy stuff man
Quick Reply: Blank Navigation screen
