Blank Navigation screen
#161
I tried the same, disconnected the battery for at least 30 min, reconnected and inserted the original DVD but nothing happened. Please can anybody send me the update file I don't find any other solution for this problem. Would be very nice!
#162
I took mine to the dealer Friday. He disconnected the battery over the weekend (he was told overnight by Jaguar). He called me by 8:00 a.m. this morning that it was fixed. They put in the update. Plaza Jaguar here in St. Louis. $149.00 total. I was pretty happy. They did think that buying the new disc for $199 would do the same thing but I didn't really want to gamble that much for a maybe. I am satisfied but just hope it lasts.
#165
Hi, I need help with a 2003 Jaguar s-type Denso navi. I messed up with the update and have a blank(black) screen. I need a software DVD to restore it. Thanks a lot. Please send it to jul13usa@gmail.com Highly appreciate it.
#170
Is it possible that you share the disc? Some ppl here already got a fix for this problem but I think they don't like to help others with it. If i get the solution for this problem i could share it and help the others!
Thanks in advance
Thanks in advance
#171
guys i posted a few threads looking for answers to this 50,51 code error. unfortunately the only way to fix this is to order a navigation update. i ordered mine from ioffer.com for about $60. its a copy of an original jaguar disc. i popped in the navigation update and within 5 minutes my screen came back to life. i was able to find out about ioffer through hours of searching through threads.if you really want to fix this problem i suggest taking my advice and ordering the disc. trust me 1000000% you won't regret it. Btw i fixed the problem on my 2003 jaguar s-type.
#172
Hi
I have sorted my blank screen!!! I borrowed a nav disc from someone else's x type, inserted it to my navigation module and after a couple of minutes the screen asked for the security code. when I entered the code the screen came up working perfectly. It also works with the original disc now too, so not sure why it needed another disc to get it going again but it is fine now. I did try copying the disc but it didnt work-sorry, but hope the info helps.
#174
PM me your email address. I will send you a file. You need to burn it to DVD-R loose then start car, remove map dvd and insert the one you burned. Screen should say updating. If it doesnt, just let it run for 1o minutes, then cycle ignition. I hope it works. If not you likely need DVD reader.
#175
I am alas in the same boat ! Nav screen blank and 50/51 showing on ext temp display. Anyone know where to d/l this file or can a member please send to my email?
#176
Hi everyone am trying to help a friend with his xtype and the screen is blank and there is the same errors coming up 51 50, not sure if I need this software that everyone is burning into a DVD but also it looks like the climate control module is missing from the boot.. does anyone know if I can purchase a module from ebay and would this work or does it need to be the part number as the old one and or could someone send me this software so I can also try to put it in the sat nav reader and see what happens, many thanks.
#177
#178
#179
Hi everyone can someone also send me the DVD update having the same problem email efr008@yahoo.com . Thanks for the help having the same 50 51 error on LCD and blank nav screen. UPDATE : issued fixed by putting in newer map/DVD disc after it read it leaping jaguar came back on screen and have all my functions back .
#180
![Wink](https://www.jaguarforums.com/forum/images/icons/icon12.gif)
My sat nav problems now sorted.
To all people posting here, let me reiterate the earlier advice. THERE IS NO SEPARATE SOFTWARE/FIRMWARE UPDATE. The software or firmware is contained with the Jaguar map dvd. This firmware gives the screen its instructions. If you have blank screen follow these instructions:
1) Try and ensure you have a verified original dvd disc. Although mine was bought back to life by a non original. The year is not relevant at this time.
2) Ignition on. Load disc. Off ignition. Start car. If the screen is still blank after 10 minutes and ext 50/51 is displayed, there is an interupt between the screen and boot dvd player. This is more than likely a faulty dvd player. The disc player is unable to read and thus cannot load the relevant software/firmware, to enable the screen, air con, etc to function.
My system was bought back by replacing the boot mounted dvd player. As soon as I replaced this the system was back up within 10 minutes.
If your system is working ie screen, air con etc, but your nav system does not (commonly displayed 'the disc installed is not a map dvd' ) then whatever you do, DO NOT go into sub menus and try and complete a system update. The notice 'the disc installed is not a map dvd' is more than likely a faulty dvd player, ie it cannot read the disc. The firmware to run screen etc is already embedded so screen continue to function, but by attempting an update under these conditions wipes the firmware, ready for the new firmware on the dvd disc, however it cannot read the disc, thus blank screen.
It is a robust sysyem just follow these instruction and save yourself an awful lot of trouble. Having no air con in 30 degrees is not fun !
Mods can you close this thread, as I and others are being mislead (although with good intentions) and waiting for this mythical software which doesn't exist. Its all contained on jaguar Map DVD.
dlnga (06-10-2014)
